Help me to get these headers to fit
Bought a top speed header and mounted it last night. Honestly I didn't expect it to fit so well, but It is about 1/3 inch too short to reach stock y-pipe. I can bolt it up but its just short enough where there still is an exhaust leak. I'm using the stock gasket since it is thicker. Any suggestions to get this to fit?? I don't think I need to weld an extension. Help guys!
if you apply torque to the nuts and bolts does it pull the exhaust closer to header? the exhaust should connect to rubber which should connect to the car, and i feel you might be able to stretch the rubber perhaps, since its only 1/3 an inch. get a friend to help pull the exhaust closer to the header
I put as much torque as I could on the bolts an it's still leaking. I even loosed the bolts from the end of the y-pipe. Gonna go to autozone tonight and see if I can double or triple up on gaskets and see if that fixes the leak.
Unhook cat back exhaust......put the heads on......and piece by piece put on the exhaust.....
It should fit.....1/3 inch is easy to find when rubber hangers are being used....
I assume your doing this on the ground, which can make the process a bit more difficult, but on a lift it's easy-breezy to move the entire exhaust system back and forth it should have plenty of adjustability..
^^^ Yes.. Disconnect the mid-pipe completely from the rear half of the exhaust and bolt the double pipe flange mount to the headers correctly, then pull the rear ypipe forward to mate to the rear of the mid-pipe. The rear y swings on two rubber hangers, and the mufflers hang from four rubber donuts. You can get like 2 inches of movement back and forth from those..
Long story short.... The Headers weren't angled correctly where it meets y- pipe so I had to double up on feltpro gaskets for one port and use a thick feltpro gasket for other side. Worked out great!! No leaks and sounds mean. In the end you get what you pay for ....... Lesson learned.
NLLex
09-05-18 01:12 PM
