LED drl upgrade
#34
Registered User
http://www.ddmtuning.com/Products/9005-LED
Will this work on the car as well? It's a super cheap replacement compared to the one you got. Has anyone tried these or know anything about these?
#42
I did this replacement too. It was a direct swap with the high beams. I was stupid and got the blue lights and if you are thinking about doing this from ijdm.com the blue ones are very illegal. They look good but it is a pain and now im regretting doing this cause I need my high beams. Plus to use them you have to keep your high beams on so they dont run naturally during the day.
#43
Namngo. The DDM LED products are actually decent. I had spent a lot of money in the past with my JAG S-Type got the full PHILLIPS HID headlight system for $500. Got the DDM system for pennies for my GS and can't tell the difference. Also they offer lifetime on their merchandise. You can't go wrong with that. For the DRL I actually put in PIAA bulbs looks pretty classy with a little goldish tint when on, when you light up the high beam it turns bright WHITE similar to LED but not quite. But I have noticed it helps when high beam is needed. Although the DRL/LED looks nice it's quite annoying for the others on the road, IMO.
