When to replace Radiator?
Hey all,
A trusted mechanic told me it would be a good idea to replace the radiator on my 98 gs400 with 140k miles. The top part of the radiator can be described as dry or brittle looking. Looks like very fine hairline cracks if u will.
I have been searching but cannot find any regular replacement interval. No one seems to include this in their 100k service along with the waterpump tstat etc.
So long story short, what are signs of radiator needing replacement and about when should they be replaced anyways?
Thanks in advance
Thanks in advance
All depends on wear. If you're seeing wear then replace it.
The key thing is this is an infrequent maintenance item, much like timing belt maintenance. If this one made it 14years/ 140k miles, maybe you can expect the new one to last another 14years.
If you see yourself going to replace it within your lifespan, you might as well replace it as soon as it is convenient; and get some good use out of the new one(rather than push your luck and drive the old used one to the ground).
I regretted trying to last on old shocks for too long, thinking the old ones were still usable. Now I realize if i changed sooner I could've get more use out of the new shocks and a well-running car rather then suffering through with the old parts.
When it leaks, replace it! But otherwise if you can see signs of the plastic starting to crack, or corrosion at the seams then it's a smart move to replace it as soon as it's convenient for you, it may save a tow and some headache down the road.
Unfortunately almost everything on a bimmer is a 'wearable' item, I have quite few friends that are into bimmers, and they are constantly replacing the same parts over and over, as well as all the typical electrical shorts and randomly working functions in the car. Very nice driving cars when new, but I'd never spend a dime on one that for sure. But after the first 50k time get friendly with the parts counter guy and a worn out debit card.
Also keep in mind that once you do replace the radiator, a few mechanic friends suggested that you should do a radiator flush ATLEAST once a year. Depending on the type of weather climage you live in (since I'm in Houston I often do it twice due to our summer heat). Doing so does the following:
1)Remove rust and deposits from your cooling system,
2)New antifreeze has corrosion inhibitor
3)All the old antifreeze is removed and the pump is lubricated with a flush
4)New antifreeze will help the engine run at the proper temperature and prevent freezing (especially if you live in colder climate),
and if you're still not convinced? Remember that new antifreeze acts as a lubricator, keeping seals and gaskets lubed in your engine in addition to acting as a rust inhibitor. Blown head gaskets, leaking intake manifold gaskets, water pump replacement, heater core replacement and radiator replacement are all examples of expensive repairs that all could be caused by failure to change your coolant.
above is mostly sound preventative advice to change out the coolant more frequently (with the manufacturer specific coolant).
The only clarification of opinion I'd throw in is most people would say you want to do a coolant Drain and Fill, and not a Flush. Not sure if you really meant Flush or you really just meant a D/F
It's pretty much similar to the discussions on changing auto transmission fluid; you can just do this partial D/F on the radiator which is a quicker easier task that you can do more frequently.
I meant a drain/fill - flushing it out. I'm sure some use different language, but essentially that's what I meant. And you are correct Ray! I'm about to replace my radiator soon as well. There are signs of leakage (I just closed in on 94k on my 05 GS430).
yea, flush typically means adding a chemical flush additive with water, or sometimes just completely "flushing" it with water until it runs out completely clear, then putting in right amount of coolant to get the right ratio (happens at the end of a chemical flush too).
So be careful if you're talking with a mechanic that you don't confuse these terms and get a service you didn't want.
then again, my pet peeve is people who use motor when they mean engine with respect to automotive repair; but i let it slide these days.
