TSB NV009-00 Window Seal
This TSB is for '98-00 GS300/400 and is to eliminate wind noise from front windows. Have any of you had it done to your vehicles and did it make a significant reduction is noise?
You'll need to put some kind of felt or foam to fill up the gap between the window weather strip and the door. Just cut a piece of felt about 20mm long and 3mm wide and tape it around that corner. Reinstall the weather strip.
when you reinstall the weather strip, make sure the top edge of the weather strip is perfectly sealed with the door frame. This will help to reduce the noise some.
VVT-i,
I'm assuming you are answering futuregs' complaint. The TSB I'm talking about requires you to remove the front inner door panel. The title of the TSB is "Front Window Wind Noise at B-Pillar lower." Am I right in assuming that this is talking about the bottom rear of the front windows?
