Successfully disabled 3rd brake light
Old 07-28-04, 05:26 AM
  #31
DaveGS4
Forum Administrator
DaveGS4's Avatar
Received 2,280 Likes on 1,386 Posts
Originally posted by T.L.W.
dave trying to disable the warning light
it comes on and goes off im just assuming its because i know longer have the spoiler on
(hoping actually)
not sure HELP lol
Hmmm. Well from looking at your pictures in this thread
https://www.clublexus.com/forums/sho...hreadid=127780
the JP spoiler doesn't have an LED third brake light in it does it? Can't quite tell.
Old 07-28-04, 07:23 AM
  #32
lexusondubs
dubsonlexus
lexusondubs's Avatar
this mod is
Old 07-28-04, 07:30 AM
  #33
DaveGS4
Forum Administrator
DaveGS4's Avatar
Originally posted by lexusondubs
this mod is
What mod do you mean and why?
Old 07-28-04, 12:01 PM
  #34
lexusondubs
dubsonlexus
well the third brakelight is there for a purpose i think to disable it is unsafe
Old 07-28-04, 12:15 PM
  #35
Neo
The One
Neo's Avatar
Although hard to tell from the pics, I don't think TLW has a third brake light any more (which I agree is a bad thing). I don't know if it is federal but the third brake light is legally required to be there in CA. I think he is just looking to get rid of the warning light but I think the "correct" solution would be to trade with someone with a deck light.
Gee, Dave, if this was the case, it might have saved you some trouble if a trade can be engineered.
Old 07-28-04, 12:26 PM
  #36
PHML
Master Thread Closer!!
PHML's Avatar
Well...if I had a JP rear trunk spoiler....I would keep the 3rd brake light working for those who have it.
For those who had OEM rear spoiler with LED brake light on the spoiler (no rear deck 3rd brake light) and replace with JP spoiler....I'd do this mod so the warning light on the dash is eliminated.
Old 07-28-04, 12:50 PM
  #37
TLW
TLW's Avatar
this is my situation thanks
phml
Old 07-28-04, 03:38 PM
  #38
DaveGS4
Forum Administrator
DaveGS4's Avatar
And that was exactly my situation as well. I definitely WANT a third brake light (like the LED one on the OEM spoiler), but I don't want the fourth one on the back deck in addition to that lighting up. I blacked mine out at first, then eventually replaced the entire back deck as well to get rid of the unsightly lump.
Johnny, have you taken bulbs out of the one on your back deck already? If not and your warning light is going on/off you probably have a burnt out or loose bulb / connection. Before you disconnect it, I'd troubleshoot why it's going off.
Edit - nevermind! You don't have one of those at all now I see...
Suggest you find someone with a 3rd brakelight deck to swap with you! Mine's been cut up or I'd do it.
Old 07-28-04, 05:05 PM
  #39
rominl
exclusive matchup
rominl's Avatar
phml
what interior you have? if it's tan, you should have traded your rear deck with davegs4! hahaha
and yes, i agree, without the 3rd brake light is a very dangerous and illegal thing to do
Old 12-18-11, 05:26 PM
  #40
GS4_Fiend
GS4_Fiend's Avatar
Need to try this tomorrow
Old 12-22-11, 03:48 PM
  #41
SELFMade
SELFMade's Avatar
Ok guys I just need a little clarification on what I need to do here. I have DEPO tails installed, and what i'm trying to do is disable the warning indicator.., without disabling any of my tailights, I want my 3rd brake light to continue working. Which DIY do a follow?
Old 02-08-12, 08:42 PM
  #42
mindnmine
mindnmine's Avatar
bump,bump,bump, i need to know this
Old 02-09-12, 02:49 AM
  #43
ebxgsxr
ebxgsxr's Avatar
Originally Posted by PHML
Ahhhhhh....finally.... got it!
Its the connector for PIN# 4 (purple and red wire).
Instead of tape...I just pushed the pin# 4 out of the plug.
You will need a small flat head screwdriver (the kind you would use to repair your eyeglasses) to lift up the white plastic snap on.....then at the same time....use another screwdriver to push the pin out.
Took me about 15 mins to push this dang pin out because its almost 1 AM and the lighting in my garage sucks..... plus my back was starting to hurt (not much slack from the plug).
Thanks JacobT!!!
Pete
Intellexual:
I have a 2001 GS3. I dont remember seeing another purple wire.....alot of green wires.
Here's an updated pic of the plug.
Pete
the 1st 2 quotes are what did it for me. i ended up just cutting that #4 wire & no more indicator light on the dash. all my brake lights still work. i don't know why the pictures didn't show with the quote. but they are on the 2nd page of this thread.
Old 05-22-12, 10:54 PM
  #44
merlin911
merlin911's Avatar
CL comes through again, helped me out a ton, now i dont have to look at that stupid orange light anymore!
flyfl1pguy
05-21-11 06:09 PM
Brent77
03-06-10 04:04 PM
T0ked
SC- 1st Gen (1992-2000)
07-23-06 10:53 AM
Hai_Nguyen
15
03-16-06 07:20 AM
RLand
RX - 1st Gen (1999-2003)
11-21-02 02:33 PM
Quick Reply: Successfully disabled 3rd brake light
