Moisture in GS headlights
headlights
I was wondering if anyone else has this problem also. I have moister in my headlights. I don't know how to get it out. It looks alittle like water is in it. If anyone can help out let me know.
headlights
Do you have HID?
Have you changed your 9006 bulbs?
To get rid of it, try using a blow dryer and check your seals... they may be bad or if you changed your bulbs(non hid), they might not be inserted properly.
Rock
Rock
Lexus dealer even told me it happens to a lot of headlights. The stupid thing is that my original right (passenger side) headlight is perfect. The left headlight on the other hand is not so good. It has been replaced with two new headlight and still has condensation. I am getting it replaced again under warranty...but this is so lame. They actually try to pawn it off like it was normal, and all I do is point to my passenger side headlight. Damn rain.
I told them to change the wiring harness...in case that is the culprit...but they keep wanting to replace the headlight...gee I guess after this one I can have them buy this car back under the lemon law and get a GS4....hahaha....better check if that will work.
I have non-HID.
I have non-HID.
I have the same problem with my driver side headlights. The dealer replaced mine and it happened again. I noticed another GS had this problem. It's funny because it only happens to the drivers side.
We had condensation in the driver's side headlight (HID) and the dealer was nice enough to change both under warranty.. No problems with condensation and now the lights look new.. Now I use Zaino 14 - Plastic Magic to keep them looking their best..
I've noticed this too on a lot of Lexus models. I was told by a body shop guy that a lot of times the condensation is caused by a frontal impact which causes the bumper to jar up into the lamp assembly and break the seal. Are your GS's pre-owned (people with this issue)? I was told to stay away from any pre-owned car with condensation in the lights.
Thanks for the heads-up.
To be honest with you guys I think almost every GS has problems with condensation in the lights.. I've had my car for 5 months now(bought it new) and mine have been replaced twice so far and will be in the shop soon for the third time.... I just think the headlights are poorly assembled..
I don't think you need a front impact to have the condensation in the headlights problem. I bought my car new and never even hit the front bumper parking and have the problem in both headlights. I will have them changed out maybe next dealer service.
exclusive matchup
nah, you don't need a front impact at all. i have check, for example the front turn signal, when you take off the bulb, you will notice that the rubber band around the power connector isn't that flexible, so it will easily allow moisture in. also, if you replace your bulb on a moisture, cold day, chances of it fogging up is a lot higher
Originally posted by BananaGS
they replaced both headlight HID under warranty.
If you meant the latter, that's pretty sweet... I think I've got moisture in my headlights
ha ha CK1_RX3
funny
99 GS400, it comes with HID, dealer replaced both headlight, for over a year now, no more condensation problem
Anh
funny
Anh
