NEED HELP!!! so i turn to you airride gods
these are what i am on now but like i said i go dont plan to buy a whole new bag kit just need a way for it to ride smoother do i just fix it by running 8 valves in total? and does somebody have a pic of the 8 valve setup oh and i just found out something else to that both sides on the front hose has leaks if i fix it would it help?
Yeah those are EAI aka The Hack Shack air cylinders. You should fix leaks regardless if it will improve your ride or not.
You can get a small 8 valve air manifold, like the Accuair VU4 or if you run individual valves u can plumb your valves this way.
Have any photos of your valve setup right now?
Lol damn Danny you just keep digging yourself in a hole bro. Sell all your shizznits, save up, and get air runners and call it a day! But you want the "lay frame". You can pancake with with UAS kits, shocks, and camber so you can do that. There some members with airrunners who said Airrunners doesnt go that low either. I'm deleting you off my Facebook for buying those whack cylinders. I'm 90% sure that noise is coming from those cylinders. Lol... You got my number you could've texted. Im on UAS and my frame is kissing the floor. And as I stated earlier, you're on fb manual kit so front move up and down together. If there's a leak in any of those front or rear cylinders, it'll make you lopsided (off balance) which in turns gives you the "boat" effect when you're driving. Make sense? If you have a fbss kit that can monitor each bag pressure by a digital gauge, you're able to see which bags has more/less pressure and you be able to pump/release air to make it balance. To make it simple and short, sell that, get UAS (again) and accuair/e-level. But if you want a cup kit, get Exotic Air cups, your BC coil overs, and swift spring to replace the BC springs. Why? BC spring radius is 62mm which fits but a tad small for the cup and swift spring is 65mm which is a perfect fit for the cup. That 3mm makes a difference! Anything else, just text me foo. EAI cylinders.... Smh ...text me.. I lost all my contacts lol
ok quick question the reds circle right now i got them run together as one tank is that right?
on the picture below which color does the red run into? dont mind the purple on the tank lol accidentally marked it and didnt notice i saved it like that
I believe the red goes to yellow. And wtf is up with your set up? Where's your drainage? Tell me you did not hook up your compressor line to your drainage exit.. And yes, you have the electric manual kit so for $650 more you can get the Dakota digital or $700 for the accuair e-leveler. Plus you need more valves. Those lines/hose should be fine.
I have the same cans on my honda u will never get a smooth ride with them to tell u from experiance and mine leaked I had to rebuild them 3 times already I also had 8 valve setup. In my gs im runnin d2 air and honestly it rides like stock.
DIAMOND777
06-30-10 08:08 PM
