Show me of the nicest headlights?
Old 06-22-12, 06:40 PM
ThomasGS4
ThomasGS4's Avatar
Originally Posted by YaKuZa_GS
I think the JDM Aristo 10th Anniversary Vertex Edition headlights tops them all with the black pearl housing. I always wanted to get a set of these and retro fit the housing into my lights but not easy to come by. I also worry about the sealing after retrofitting.
I completely forgot about those. Those are definitely the best.
Old 06-22-12, 08:40 PM
VIPvPanda
VIPvPanda's Avatar
Do the LS600 projector headlight retrofit ;]
Old 06-23-12, 01:20 AM
perry05g35
perry05g35's Avatar
^ Post more pixs!
Old 06-23-12, 03:38 AM
usa5655
usa5655's Avatar
wow that is sick!!!
Old 06-23-12, 11:10 PM
VIPvPanda
VIPvPanda's Avatar
Uhhh sorry guys that's the only picture I could find of the car. But the guys overseas either use custom LS600 brackets for the retrofit, or the real deal. I've also seen the 5 projector headlight in the outers, just trying to find them right now
Old 06-24-12, 11:52 AM
Mr Jokster
Mr Jokster's Avatar
Originally Posted by cschroder
use the "cv" brand. follow the directions and your headlights will look brand new. you can get it at autozone. its 25bucks. comes in a foil pouch. here's the website.
http://www.myheadlight.com/
pretty simple. sand with 800 grit, then 1000 grit then polish with rubbing compound..then apply the super secret ingredient...and shazam brand new looking headlights.
Originally Posted by themccoy14
If you want to clean up your headlights a little trick I learned a while ago was using wheel polish like meguiars mag and aluminum on the lenses. You can just use a cloth. That stuff is great for everything. After I get done cleaning up the lenses I wax the headlights and they look brand new.
This way is garbage. If you're lucky you'll get 6 months of clarity, but usually 3. These "restorations" are for the OLD plastic ones that turn yellow because ANYTHING is better than what those look like. You do it for the little fogging we get, sure it will look ok, but once it all wears off, it becomes worse than what it use to be.
The ONLY way it should be done is the exact same process with the sanding but then get them clear coated, cut and buffed and you'll be good to go forever.
Old 06-24-12, 11:57 AM
Mr Jokster
Mr Jokster's Avatar
and yea, oem best way to go.
you should do a retro fit with q45:
or LS430:
or any other projector. the q45 LOOKS best, the LS430 preforms BEST. LS460 fills the cavity better, but not as pretty.
M45
FX-R
When doing the retro fit, thats a great time to get the lenses clear coated on both the inside and outside. Doing this can kill 2 birds with one stone and save lots of money.
Old 06-24-12, 01:33 PM
671gs
671gs's Avatar
Nice.........
Old 06-24-12, 01:34 PM
tmf2004
5% Club. Killing it!!!
tmf2004's Avatar
Great looking lights... What happened to the Vender that used to make these?
Old 06-24-12, 01:44 PM
Hollywoood
Hollywoood's Avatar
these lights are a good upgrade
Old 06-24-12, 03:21 PM
apentivolp
apentivolp's Avatar
the Q45 retro are SO NICE...
Old 06-24-12, 07:15 PM
tmf2004
tmf2004's Avatar
There's some JDM OEM lights on ebay right now... GL
Old 06-24-12, 07:50 PM
usa5655
usa5655's Avatar
q45 retrofit looks good...how much do they go for??
Old 06-24-12, 11:59 PM
2GSC300
2GSC300's Avatar
How about these outta JP.....
Old 06-25-12, 12:04 AM
tmf2004
tmf2004's Avatar
do u have a link to those lights?
Quick Reply: Show me of the nicest headlights?
