Show me of the nicest headlights?
#76
Anyone in the OC/LA area with experience doing the retro interested in helping me out?
I currently have a set of the green tint and chrome HID headlights. Both need work done.
Would like to get new lenses. what would be the best option.
#77
This way is garbage. If you're lucky you'll get 6 months of clarity, but usually 3. These "restorations" are for the OLD plastic ones that turn yellow because ANYTHING is better than what those look like. You do it for the little fogging we get, sure it will look ok, but once it all wears off, it becomes worse than what it use to be.
The ONLY way it should be done is the exact same process with the sanding but then get them clear coated, cut and buffed and you'll be good to go forever.
ArpusTT
01-24-18 06:35 PM
redsc400
SC- 1st Gen (1992-2000)
32
11-06-10 10:40 AM
