PCV valve replacement would you be worried?
Old 07-05-12, 12:22 PM
sakataj
sakataj's Avatar
Originally Posted by GSteg
Engine cover needs to be taken off, but not the valve cover. It's an easy install.
i wouldnt say its that simple henry, i did it when my PCV grommet broke also and fell into the housing. i was using a pocket screw driver to pull it out and was on my last part when the screw driver shaft fell out and into the valve cover (so now i def had to remove the valve cover) its not so much a hard job but its very time consuming ,tedious job ESPECIALLY the drivers side as the wiring harness is really in the way and you have to remove so many things just to get the valve cover off....hell i had to go buy some swivel or a universal socket to get to those 10mm bolts out
Old 07-05-12, 03:49 PM
GS4_Fiend
GS4_Fiend's Avatar
I admit the OEM pcv is thick. Had to use special fitted pliers to yank it out. Lucky me i didnt crack my gromet. Installation is easy though.
flux702
Performance & Maintenance
04-29-20 08:08 PM
nezlyfe
07-11-15 01:40 PM
autoboy
SC400 / 300 Classifieds
02-16-13 10:01 AM
JoeInHNL
10-28-11 07:58 PM
Quick Reply: PCV valve replacement would you be worried?
