Help with identifying headlight/signal harness for non hid pics
I'm looking to find out if I can just connect lights to these or do I connect to a harness. If so, which harness do I need?
Top one is a 900x and the 4 pin grey on is for the turnsignal and city light, there is one more 900x connector on the car right near where you took the pic, for the low beam and should be tucked just to the right of the ecu box where the fender meets the core support.
The two 900x connectors will connect to each the 9006 low bulb and 9005 high bulb directly, the 4 pin grey on will connect to a short wire that should be attached to the headlights when you get them, which in turn have the sockets for the 7440 turn and 194 city bulbs.
Well I got the headlights but no bulbs it wires. I'm mainly looking for the signal light holder or sockets that the 7440 go into. . Where can I get those?
