Whats up guys, I just installed a Greddy exhaust, sounds great but still in the AIR, i notice that its sitting crooked when looking at if from the back how do you adjust it? I just bolted it all up any DIY?
I got the exhaust right the mid pipe was upside down,
"Zip tie the exhaust hanger to the other hanger. But don't do it tight, just enough to bring it up."
I am going to do this to make it perfect, it is still just a little tad off and will probably bring it up though sounds awesome.
what people normally do is loosen up all the screws... shake the exhaust around until it lines up... and bolt up little by little across all the bolts.
^^^^This.
It's how you do it, wayyy easier on a lift, but can be done on the ground. Loosen everything and go around loosening/snugging the sections while moving and adjusting the tips into place. It can take alot of time and checking/rechecking to get perfect. But the Greddys are built great, they will line up with some work unlike the ebay exhaust(s) that I've had to cut/bend/weld to make fit better cause they were not even close to fitting properly.
New rubber hangers for the mufflers and y-pipe can make a difference as well if the are old, cracking, or dried out.
i think he said the mid pipe was upside down, simple mistake with the greddy exhaust. should have looked at the pics in the diagram a little closer lol.
