po 446
![Red face](https://www.clublexus.com/forums/images/icons/icon11.gif)
Hello can anyone hep with this my check engine light is on went to have it tested and came up with code po446 probable causes
aa1 open or short circuit condition
aa2 poor electrical connection
aa3 faulty vent solenoid
my lexus is 2000 GS 300
I really have no clue about cars but im trying to learn , so if anyone can tell me what to check or how to do it please help
I have changed new spark plugs last week, I have tightened gas cap, i have disconnected battery,
lost now please help
and a woman going to a mechanic is like a kid in candy store
so any info would be great
Thank you so much
Thank you so much
Where are you in Texas? maybe someone on this forum can send you to an honest mechanic that knows the Lexus very well
Happy reading
https://www.clublexus.com/forums/tags/po446.html
Happy reading
I am Arlington Tx area, I am trying to do the work mostly myself as it Costs an arm and leg at mechanic and if i can do most myself, it better.
Has anyone came across this code and if so what did y'all try
Thank you very much
Thank you very much
i just got this fixed it can be either a simple hose leak or something more extreme like your charcoal canister. . . . mine was just one of the sensors $80 sensor i checked all the other sensors and one was bad and not responding with my mechanics tool. . . . .replaced it and 2 weeks later it never came back. . . . Hope this helps
RX 300 Year 2000
Is the Solenoid...within the Vent Control valve?
Can you see the VCV without having to move the air filter housing?
I say this because is it on the OUTside of the air filter housing or WITHIN the housing...but on the bottom after
taking OUT the air filter.
Where is the Solenoid?
thank you.
Last I checked..behind the air filter was a short hose...about 5 inches I guess...it was disconnected. The PO 441 and others were erased
but will have to wait for the cycle to go through to see if it was the hose disconnection that caused those errors...or it could be the solenoid
which I have NO IDEA where that is..thx
thank you.
calvin2376
12-19-14 01:18 AM
