Another Retrofit M35/45 Projectors
Old 02-09-13, 04:51 PM
  #31
monkey92
monkey92's Avatar
Can you give me more info on that?
when you space the lens away from the base where it sits it will start to give you more color, and the cutoff line becomes more define and sharper. idk if this answered your question about clarity.
Old 02-11-13, 06:21 PM
  #32
tn96dc
tn96dc's Avatar
Any idea what the ideal spacing will be?
Old 02-12-13, 04:42 AM
  #33
sinistervr
sinistervr's Avatar
how come your projector does not look centered but pushed more to the outside?
Old 02-12-13, 10:29 AM
  #34
monkey92
monkey92's Avatar
it really depends, every projector is different, i suggest have the projector hooked to a battery like i did and test with spacing the lens while aiming it at a wall about 20~ ft away until you like what you see. some people use gauge wires but that was too thick for me so i just cut out rings of construction paper and stacked them until i got the desired setting, also switching to clear lens and doing the spacers will really help alot. hope this helped. here are some examples of color mod and sharp cutoff.
http://www.theretrofitsource.com/pro...roducts_id=135
Old 02-12-13, 03:16 PM
  #35
BiGEZ
BiGEZ's Avatar
That is how it is mounted using the brackets I got from Tony at Luxury Mods. It moves the projector out a bit and that gives a much wider light output.
Yes I know some night shots is long overdue but I can't seem to get the right shots that does justice to the light using my crappy camera.
I can say the light output is super wide and with a nice cutoff. Well worth the time and $$$. I can get a little more light it I remove the headlight lens and polish it clean. Did not do that when I had it apart.
Old 02-12-13, 03:32 PM
  #36
Acer
Acer's Avatar
Why not polish the outside
Old 02-12-13, 09:20 PM
  #37
monkey92
monkey92's Avatar
me and you both lol
Old 03-07-13, 09:40 PM
  #38
BiGEZ
BiGEZ's Avatar
Some night shots. need to work on the cutoff but happy with it for now. Looks a lot better with the naked eye
URL=http://imageshack.us/photo/my-images/802/20130307231338.jpg/]
Old 03-08-13, 07:43 AM
  #39
nar8ta
nar8ta's Avatar
Looks great bro
Wet sand and buff the lenses.
Patsum
01-03-13 01:50 PM
MumRah
SC- 1st Gen (1992-2000)
13
12-13-11 09:41 PM
97lexus
11-18-11 04:32 PM
RacingLuxury
09-14-10 11:30 PM
lexus4jess
02-21-06 02:14 PM
Quick Reply: Another Retrofit M35/45 Projectors
