Help driver side courtesy light is out! short circuited***
Old 07-08-12, 08:15 AM
Sheehan1p
★ I
Sheehan1p's Avatar
Default Help driver side courtesy light is out! short circuited***
Hey CL i was wiring up leds strips to the driver side and i guess the two wire touch'd and no it wont come at all... do you guys think it might be a fuse because im so lost. Much help is appreciated thanks! This is that bottom light that turns on at the bottom of the door when the door is opened
Sonny
Old 07-08-12, 08:17 AM
ThomasGS4
ThomasGS4's Avatar
Door ECU? Does the main light turn on when you open that door?
Old 07-08-12, 08:19 AM
Sheehan1p
★ I
Sheehan1p's Avatar
well that bottom one used to turn on until the two wires touch now it does not turn on at all but if your talking about the dome light yes that does turn on
Old 07-08-12, 01:25 PM
GS4_Fiend
GS4_Fiend's Avatar
Definitely fuse, check passenger kick panel.
Old 07-08-12, 02:33 PM
Sheehan1p
★ I
Sheehan1p's Avatar
Okay will do I'll let you know what happens!
Patrick92
02-25-15 08:06 PM
Kawai4eva
RX - 1st Gen (1999-2003)
01-17-13 11:12 AM
vboi4life
06-11-12 09:55 AM
o2k
08-29-10 11:35 AM
piggieback
11-08-09 08:06 PM
Quick Reply: Help driver side courtesy light is out! short circuited***
