drivers door handle lock not working
Old 07-15-12, 08:54 AM
Silvermtb6
Silvermtb6's Avatar
Default drivers door handle lock not working
Has anyone else had this problem? When I open the drivers door and shut it then come back to open the door, it is locked. I thought it was the actuator but the lock/unlock button and key fob works properly and the lock indicator goes full lock/unlock when doing that. But, when I open the door with the handle, I found that the lock indicator does not open, therefore the car still thinks the door is locked and if the lock is in between lock/unlock, the car locks the door behind me. So I am thinking it is a problem with the door handle itself. Any input?
Old 07-15-12, 09:05 AM
ThomasGS4
ThomasGS4's Avatar
I'm leaning towards the door ECU. Do the interior lights turn on when you open that door?
Old 07-15-12, 11:53 AM
Silvermtb6
Silvermtb6's Avatar
Yes, the lights come on. Everything works normal other than the lock indicator when opening the door with the inside handle.
Cliffayre
02-20-19 05:27 AM
Toh
10-02-15 07:15 PM
Lexus400mn
SC- 1st Gen (1992-2000)
07-07-07 08:17 AM
Chris98vob
GX - 1st Gen (2003-2009)
03-03-07 09:19 AM
Quick Reply: drivers door handle lock not working
