1999 gs400 doesn't start - then it does?
Old 07-17-12, 04:01 PM
mbrown1782
mbrown1782's Avatar
Default 1999 gs400 doesn't start - then it does?
I have a problem that I haven't found exactly the same issue on these great forums. If I leave my car unstarted for a few days (like over the weekend or longer), I have a heck of a time stating the thing - all power comes on but won't turn over for a good 10-12 cranks. However, once it's started it starts and runs just fine everyday...
Is this a starter issue? If so, why does it seem to do just fine as long as I run it every day?
Old 07-17-12, 04:12 PM
SC400slide
In Recovery Mode
SC400slide's Avatar
It's a cold start issue.
You could clean the throttle body, alternator or battery issue, tune up, Could be anything really.
What have you recently replaced/serviced?
also check the battery terminals.
Good luck
Old 07-17-12, 05:10 PM
ThomasGS4
ThomasGS4's Avatar
Your starter is on its way out. Same symptoms I experienced.
Old 07-17-12, 05:40 PM
Enigmatic
Enigmatic's Avatar
How old is your battery and what condition is it in? If your battery is not the culprit then I am definitely leaning towards your starter.
Old 07-17-12, 05:51 PM
Arcadian
Arcadian's Avatar
Check battery first, then starter. It does seem though that these cars really like a good battery and they get cranky on even a moderately low battery.
Old 07-17-12, 05:52 PM
mbrown1782
mbrown1782's Avatar
Thanks all - the battery is pretty new and still in good shape. I was guessing the starter also but it doesn't make sense to me why it acts just fine as long as I'm starting it every day
Old 07-17-12, 05:59 PM
clos430
clos430's Avatar
Sounds like a fuel problem, maybe fuel pump is going out ? Check the fuel pressure when the car has been sitting for a while and giving you the problem.
Old 07-17-12, 06:03 PM
Busha
Busha's Avatar
Sounds like your starter mine used to do the same and then it just got worse ... Cost me 750$ with labour
Old 07-17-12, 06:41 PM
mbrown1782
mbrown1782's Avatar
Yuk - that stinks! I noticed today too that my vsc on / off and abs idiot lights came on. Car runs fine - is this issue somehow related or are things just starting (no pun intended) to fall apart?
Old 07-18-12, 07:19 AM
Busha
Busha's Avatar
That's due to a bad abs sensor
Old 07-18-12, 07:40 AM
CleanSC
CleanSC's Avatar
All those symptoms point to a possible weak alternator.
Have it load tested before you do anything expensive.
Old 07-18-12, 02:10 PM
mbrown1782
mbrown1782's Avatar
Thanks CleanSC - I will get that checked out 1st!
Old 07-23-12, 06:33 PM
roccyGs400
roccyGs400's Avatar
Its ur starter cause mine took a crap on me last weekend and its been going out for almost 4 months now and finally died lol so i ordered the starter rebuild kit and will fix this problem next week
Old 07-23-12, 11:24 PM
sakataj
sakataj's Avatar
just a heads up guys
here is a DIY for the V8 model starter rebuild along with the part #'s in post # 18
https://www.clublexus.com/forums/gs-...-problems.html
Old 07-27-12, 12:14 PM
gs3some
gs3some's Avatar
Its def your starter going. The same thing happened to me 2 weeks ago, had the starter replaced and problem gone. I had a tread going with this same issue.
Quick Reply: 1999 gs400 doesn't start - then it does?
