left tail light went out BRAND OEM NEW
Old 07-25-12, 07:39 AM
clawmoolah
clawmoolah's Avatar
Default left tail light went out BRAND OEM NEW
i installed a brand new tail left (LEFT)
and two weeks after installed the top went out and needed to be banged to turn on
2 weeks after now no lights are on expect the turn signal....
HELP
im in brooklyn
Old 07-25-12, 09:28 AM
lexo98
lexo98's Avatar
Did you install them? From what I remember I changed my lights and wire harness but used the same old bulbs. Also if you touch lights with bare hands the oils from your skin cause them to get hotter than normal when you turn them on. Sometimes it makes them burn out.
Old 07-25-12, 10:09 AM
clawmoolah
clawmoolah's Avatar
I threw out my old taillights-- and never touched the actual new bulbs tho?.just banged the housing from outside
Old 07-25-12, 10:40 AM
nyc80rick
nyc80rick's Avatar
Make sure your wire are plugged in good. If it is could be a short somewhere also check your fuses.
Old 07-25-12, 10:51 AM
MikeFoxx
MikeFoxx's Avatar
If ur banging the housing to make the "bulbs" work... My guess is that u had the same agressive approach plugging in the wire harnesses and shorted a wire because banging the outside of a light lens should not turn a bulb on or off.
Old 07-25-12, 11:27 AM
clawmoolah
clawmoolah's Avatar
Well to put it in was "fairly" easy just plug and screw no force
Old 07-25-12, 12:14 PM
geeznuts
geeznuts's Avatar
If its oem lights.... Just change the bulbs? New or old they can go bad. It's just a small thin wire in the bulb so they can go bad.
Old 07-25-12, 12:28 PM
PHML
Master Thread Closer!!
PHML's Avatar
buy some new bulbs and call it a day!!
Old 07-25-12, 12:31 PM
DosyBoy
DosyBoy's Avatar
This is happening to my old LED tails right now, if i bang on the light some parts will light back up then go off, i switched them out with new ones and the new ones ALL lit up with no problems, change the bulb and your good, very easy, if not, send it back and get another, u should have at least a 90 day warranty...
Old 07-25-12, 01:16 PM
Mr Jokster
Mr Jokster's Avatar
LoL. It never ceases to amaze me some ignorance's! I like how he said he just bought a brand new tail light (as if blaming the tali light itself) haha I'm with you Phil, just buy a bulb y vamanos!
Old 07-25-12, 07:32 PM
porn-adkt
porn-adkt's Avatar
SIghhh... GS owners and BulBs.... Amazing
Old 07-25-12, 07:48 PM
ThomasGS4
ThomasGS4's Avatar
Meanwhile in clawmoolah's home...
Old 07-26-12, 07:34 PM
clawmoolah
clawmoolah's Avatar
well thanks for the help....
Old 07-26-12, 09:02 PM
MikeFoxx
MikeFoxx's Avatar
Sooo ur saying u checked all the bulbs and wire connections?
Old 07-27-12, 09:02 AM
clawmoolah
clawmoolah's Avatar
no their still going on and off
Quick Reply: left tail light went out BRAND OEM NEW
