Pass Fuse box removal/install
Been searching for a couple of days now on how to install the passenger side fuse box, (fuse panel), or (fuse holder).
The reason is that I was in an accident I was hit on passenger side and the ABS sensor (module) which is directly behind fuse box was smashed along with the fuse box being cracked and pretty much destroyed.
So I ended up removing the fuse box by removing the glove box and amp. Some of the tabs were broken so it was easy to remove.
But trying to put it back seems impossible unless I remove more components. Which I'm a lil timid to touch.
So in other words has anyone ever removed or installed this fuse box???
I would like to find a DIY or detailed instructions on the easiest way to re-install since it is much more difficult to install then remove.
Thanks for your knowledge.
Been searching under fuse box or fuse panel with no luck.
iModerate
To my knowledge this fuse box was never intended to be removed and re-installed. The procedure to replace the part that you had to replace most likely does not involve removing the fuse box.
What was the part you had to replace?
PickupStix
01-06-16 03:56 PM
