Adding Navigation to a non Nav GS 300
The antenna plugs directly into the nav ecu. My goal was to use the unit for ac/stereo controls as my stock non nav stereo LCD is slowly dying and has annoying whine :/. If you want complete functionality, you’ll need to tap into a speedo wire and wire up the nav system audio to the speakers. Unfortunately I’m from from Europe, but I can provide you the schematics of the wiring so you can diy it. Good luck with your project nevertheless !
Hi, thanks for the additional info, I got it. I likely wouldn't use the nav either.. Hmm,, I may try to source the 2001+ Nav head-unit, I don't know when I'd get everything together, nor that I'm capable of wiring it up correctly, but I use a knowledgeable car audio guy who I"m sure would understand what to do w/the help of your schematics, if I could trouble you to send?
The instrument panel junction box has one free connector slot on non nav cars which you can use to get acc/rem etc. You can access it by removing the middle clock and ac, its right in the middle of it. If you need more help hmu.
These should be able to get you on the track: https://imgur.com/a/zPEap8W
rpk2012
02-23-15 03:58 PM
KeysRx300
08-16-09 07:38 AM
