Going from Aftermarket HID kit back to OEM. Could use some assistance.
Hey everybody,
I got a 2003 GS300 SD, and one of the HID lights went out the other day. So I get online, order new bulbs, and go to put them on the car. Looks like the previous owner, for whatever reason, decided to put an HID kit on the car, when the car came with HID lights to begin with. So needless to say, the bulbs I have don't match what's on the car. Here is a picture of one of the A/M ballasts that's on the car.
![Going from Aftermarket HID kit back to OEM. Could use some assistance.-qaxsc.jpeg](https://www.clublexus.com/forums/attachments/gs-2nd-gen-1998-2005/502026d1683166648t-going-from-aftermarket-hid-kit-back-to-oem-could-use-some-assistance-qaxsc.jpeg)
I want to go back to OEM, my question is, how big of a pain in the *** will this be?
The kit is made by a company called VIPHID, or that used to be their name, anyway. The bulb isn't a D2R bulb, this is what it looks like:
![](http://www.sanhuahid.com/pages/UploadFiles/20071226192655.jpg)
It doesn't screw into a plug of any kind, it's just wired directly to the ballast, which obviously makes changing the thing a PITA... I don't have the OEM connectors that a bulb would screw into, and I have no idea what to do from here. Any help would be greatly appreciated.
I did find this: Would two of these be all I need? See part# 81125 on the diagram below:
![](http://lexus.sewellparts.com/images/oem/1400x1000/810894.jpg)
No, don't get the 81125, that's for your turn signal and city lights, you already have those on your headlights. What you need is the D2R bulbs (81110L), the ballast (85967), the o-ring for the ballast (81128B). You should check under the headlight housing first to see whether the OEM ballast is still there or not. The price for the OEM ballast is kinda steep, so probably buying a whole aftermarket set of D2R HID retrofit kit is better for you. That's just my suggestion.
I am actually on the same boat as you, mine was replaced by aftermarket HID by the previous owner. I am currently trying to mount the aftermarket ballast at the OEM mounting location under the headlight. And I am actually modifying the H7 HID retrofit bulb to fit the D2R mounting perfectly. I can get the focal point of the H7 HID bulb at the same location as the original D2R. Obviously you don't have the shielding as the D2R.
Yeah, this approach can be done too. Cheaper than going full OEM. Mount your ballast under the housing, use the OEM hole for the wiring, use proper rubber grommet, and hopefully the previous owner still save the OEM plastic cover behind the lowbeam reflector, or if they made a hole, patch it up with JB weld, or replace it. The plastic cover should be pretty cheap.
The adapter that you need is the one from the ballast to your D2R bulb. Because the plug is totally different between the aftermarket bulb and original D2R bulb. D2R bulb has round plug. Aftermarket HID bulb has 2 wires with 2 separate connectors.
From your pictures, I think the bottom plug is the one that goes to your D2R bulbs, so the adapter will connect to that wires. The top one is the power source for the ballast that comes from the headlight relay system/headlight switch.
