No power to or from all windows??
Old 08-02-12, 11:55 PM
DosyBoy
DosyBoy's Avatar
Something is bad or disconnected behind the drivers door panel, take it off and inspect.. It def sounds like it has to be a fuse, i dont understand..
Old 08-03-12, 06:53 AM
ARISTOh
ARISTOh's Avatar
I've removed all 4 door panels, and checked every fuse. I need a diagram that shows me exactly where each wire is going starting from the battery all the way the the window motor, everything else works fine
Old 08-03-12, 07:16 AM
SC400slide
In Recovery Mode
SC400slide's Avatar
Read this thread. https://www.clublexus.com/forums/is-...dont-work.html
Resetting the system should be in your owners manual.
(If the the power windows switch don't illuminate than you need to reset it)
Old 08-03-12, 11:08 AM
ntran18
ntran18's Avatar
The factory repair manual & wiring diagram can be found in one of the resource sticky threads.
Old 08-05-12, 10:27 AM
ARISTOh
ARISTOh's Avatar
im still stuck guys, I went thru the manual here..
http://bahamutcars.free.fr/workshop/...nts/index.html
and I cant find anything, the door lock switches work, and I get power to them but im not getting power to ONLY the windows..im really confused is there a Lexus electrician in the house?
Old 08-05-12, 10:34 AM
Heyboss2JZ
Heyboss2JZ's Avatar
Hey bro try to research on how to reset your windows switch, this happened to my buddies is250 and all I did was reset them. It worked right after that.. its something like that FLOCKOS4 said holding the switch down or up.
Old 08-07-12, 09:23 AM
ARISTOh
ARISTOh's Avatar
I've done that, and I'm sure the dealer tried that as well.. It's looking like I'm going to have to bring the car back to them and take out a mortgage to figure it out cause I'm not able to find any help or any leads
Old 08-14-12, 11:57 AM
str8lucky
str8lucky's Avatar
You ever get it to work. It looks like i had faulty connection to fuse panel. Was messing around a bit with it and all my windows work now. Now just need to fix my doors cant unlock or luck with key.
brett14
SC- 1st Gen (1992-2000)
11-10-16 01:20 PM
jmatthorn
GX - 1st Gen (2003-2009)
04-28-16 05:08 PM
Jboswald
ES - 6th Gen (2013-2018)
01-30-13 04:07 PM
blaktony
06-06-09 07:03 AM
Quick Reply: No power to or from all windows??
