100K+ Tune-up
Hello CL,
I'm doing a tune up on my 02 GS3. Changing
.Timing belt
.Cam seals
.valve cover gaskets
.front main seal
.water pump.
Other than oil, air filter and spark plugs nothing has been changed.
Any suggestion on what else I should look into changing... gaskets,Fuel filter, tensioners.. etc???
Car has 115k+
Any input would be appreciated. Below are the prices I got for OEM parts. LMK if its a deal.
TIMING BELT $ 23.29
CAM SEAL $ 4.81 X 2
VALVE COVER GASKETS $ 8.74
TIMING COVER GASKETS $ 13.42,
WATER PUMP $ 111.22
.Timing belt
.Cam seals
.front main seal
.water pump.
Car has 115k+
TIMING BELT $ 23.29
CAM SEAL $ 4.81 X 2
WATER PUMP $ 111.22
Thanks Blanco, Will do, I'm having a mechanic do the service since im too busy to do it my self.. Anyone have an idea what should be a fair cost just for the labor?
@LOWGS300..Motion Motorworks by Tamiami airport is the shop. I pretty much interviewed the mechanic/owner and he was very knowledgeable. I feel comfortable allowing him to do the work. plus he came recommended from several friends.
Thanks for the info Neegroy and Blanco.
