Need advice on which engine code reader to buy
Old 08-05-12, 06:27 PM
Garand66
Garand66's Avatar
Default Need advice on which engine code reader to buy
Hey folks,
I recently purchased a 2002 GS300 with 58,000 miles. The search function didn't up much, so I was wondering if anyone can recommend an engine code reader / diagnostics scan tool.
I found this one on amazon.com:
Autel MaxiScan MS300 CAN Diagnostic Scan Tool for OBDII Vehicles
Amazon Amazon
Is this device compatible with my car? Any other recommendations?
Thanks!
Old 08-05-12, 07:10 PM
tiger4life
tiger4life's Avatar
I bought mines from autozone. It was $100 I think. Check the manufacturers site and it will tell you what it's compatible with. It's obd2 so it should work.
Old 08-06-12, 08:52 AM
Debonair
iModerate
Debonair's Avatar
If your car is a 1996 or newer it is OBDII. The CAN Bus OBDII protocol was added to the 3GS so this is not as important for the 2GS. So any scan tool that is OBDII will work with your 2002 GS's engine and emissions codes and possibly data depending on the scanner.
There are also more advanced scan tools that will allow you to access the other systems like SRS (airbag), ABS, HVAC, Body, Cruise Control, etc. The more systems the more money you will spend on the scanner.
A basic OBDII scanner like what you found on Amazon is all most DIY'ers need.
Old 08-06-12, 09:17 AM
sinstrex
sinstrex's Avatar
Originally Posted by Garand66
Hey folks,
http://www.amazon.com/gp/product/B00...=5336108637-20
Thanks!
I have the exact same one. It works great with my 2002 GS430 and would work great for you too. Its pretty basic. It just shows you the engine code and you can clear the check engine light(CEL).
If i would spend my money again, i guess i would buy the Autel MaxiScan MS309. Search amazon for the same. It displays the code along with what the code means. MS300 just displays the code, which you can search on clublexus or google it.
Old 08-06-12, 11:19 AM
str8lucky
str8lucky's Avatar
The scanners are pretty cheap I always thought they were much more expensive.
Old 08-06-12, 04:09 PM
sam12345
sam12345's Avatar
Get a scan gauge then you can also monitor nearly everything plus it's great for zero to 60 and quarter mile acceleration as well as braking test. It also tracks your gas mileage. So instead of having just a code reader and reset you have something you can use everyday. You can monitor real time water temp (the actual temp not the one with a huge dead zone like the gauge on the car) timing, closed or open loop, intake temp, throttle position, and about another 10 more I can't remember. It also has an estimated horse power that you can adjust if you ever get on a dyno, instant gas mileage, daily gas mileage, per tank gas mileage.
Old 08-06-12, 07:30 PM
drgonzo370
drgonzo370's Avatar
If you have a smartphone, get an ELM327 Bluetooth OBDII reader. I have an Android phone (so can't speak from an iPhone perspective but pretty sure there are comparable apps), spent $40 on the BT OBDII reader and $5 for the full version of an app called Torque. Reads all my codes, clears them, and monitors quite a few sensors and can do 0-60 times etc too (never tested that part) all from my phone or my in car MP3 player (also android). Nice while driving if a CEL pops on you can check it immediately instead of having to stop and hook up your scanner or wait til you get home.
Old 08-06-12, 10:17 PM
sam12345
sam12345's Avatar
Sounds similar to the scan gauge but cheaper.
Here is a link to scangauge II
http://www.scangauge.com/products/scangaugeii/
Here is a link to the elm327
http://www.meritline.com/elm327-blue...--p-61686.aspx
Here is a link to garmin ecoroute hd if you already have a garmin with Bluetooth
https://buy.garmin.com/shop/shop.do?pID=38354
Old 08-06-12, 10:31 PM
sam12345
sam12345's Avatar
I have the garmin ecoroute hd and the scan gauge II I like the looks of the garmin better (they look like actual gauges) but the versatility and information on the scan gaugeII is better. Maybe drgonzo can elaborate on the elm327
Old 08-07-12, 08:31 AM
FrankT
FrankT's Avatar
X2 on the Scangauge. I love mine.
I would also look at the ultra-gauge.
Old 08-08-12, 10:21 PM
Garand66
Garand66's Avatar
Thanks, everyone for the feedback.
Old 08-09-12, 12:57 AM
1sWt2GS
1sWt2GS's Avatar
i just borrow my friends
Old 08-09-12, 11:30 AM
str8lucky
str8lucky's Avatar
Wow, the app way sounds great I will do a lil more research before I buy one this weekend.
Old 12-31-15, 03:30 PM
kenworth75
kenworth75's Avatar
Default Help
I Need advice on which engine code reader to buy , I have a 1998 LS400 20 SER built to Australian standards, I have tried different code readers OBD11 ,my car dose not state it is OBD11 they say they will read my model but it dose not
Old 01-01-16, 11:24 AM
Debonair
iModerate
Debonair's Avatar
I think you mean OBDII, which stands for On Board Diagnostics 2. I read somewhere that Australia Toyota (& Lexus) vehicles did not become OBDII compliant until mid 2000's. You may have a hard time finding a low cost scanner that works. A OBD or OBD1 toyota scanner may work.
Quick Reply: Need advice on which engine code reader to buy
