puddle light question im stuck somebody please help
hey guys so i am installing my puddle lights but i want to get it tap to come on and fade with the dome light is how can i tap into the dome with out tearing apart the whole top apart? how is everyone running theirs? thanks guys
I fed mine through the A-pillar (had to remove A-pillar cover) and then ran a snake to the dome light to avoid taking off th roof liner. This is the best method in my opinion. When I unarm my car the light come on and fade off with the dome light. And of course come on when you open the doors. Not to mention you can use the dome light switch as a override if you wanna keep them on for show.
My old car I connected it to the footwell lights in the bottom of the door. But only come on when you open the door. I don't recall them fading off tapped to the footwell lights.
Ok guys so I'm tapping it to the foot well light which wire do I tap into because I tried both and I ran the black on the car for ground but it stayed on and did not turn off
