Need help with shifter (upadate with video)
http://i473.photobucket.com/albums/r...y/20af87fb.mp4
Okay so when I shift through my gears, the gear selector moves smoothly until I get to "m" (the gear which enables you to use tiptronic) at this point it takes a lot of effort to get it into gear, but when it's in the gear seems to be working fine. Also when I wiggle the shifter up or down it seems to slide into gear a little easier, but it will not glide straight across like it's supposed to. Other than that it will smoothly slide out of the gear, just not into it. Any suggestions or input would be awesome. Thanks
Alright so I found out its coming from this piece
Rubbing against this piece
So yeah, I'm guessing eventually it's just going to grind down the plastic. Guess I just have to live with it for now.
I assume if you replace the whole thing it should work but you need to figure that out
Look at this
https://www.clublexus.com/forums/2ge...-clearing.html
https://www.clublexus.com/forums/2ge...s-must-go.html
Look at this
Ltaboso
IS F (2008-2014)
12
05-26-15 09:44 PM
