Burping my radiator system HELP
My radiator cracked so i replaced it and my thermostat now car is over heating still
Ppl are sayin i got air n my system but no idea how to get it out
Any advice is greatly appreciated
Thankyou
Thankyou
When car is at idle with radiator cap off it dosent over heat i put cap on and drive it .2 miles it over heats already swapped radiator and thermostat out
Do GS's run clutch fans? If so, check that out as well. If the clutch fan stops spinning the car will possibly overheat. A great way to test a clutch fan is attempt to spin it. If it spins more than a couple of times in rotation without any resistance, then it's bad. Very simple to replace. But some of the others mentioned a few ideas, stuck thermostat and bad cap could be the culprit.
Like everyone else mentioned. I do not believe its air in ur system, sounds like water pump, t-stat, or cap.
But for the record I had to "Burp" and LS400 once and basically just opened up the drain valve on the bottom of the radiator and let some coolant out until it was a nice stream, then filled up the system.
replace your thermostat and cap.... you'll already be in there so why not unless your low on funds... if not, take out the thermostat and test it in boiling water and see if it opens. If it doesn't.. replace.....
I'm assuming it is because the top is hot and bottom is cool.
