2nd gen GS wheel size/offsets
Has anybody put together a chart for what offset you need for rim size and width ?
I'm at the stock 17's on a 2004 gs430, I've had the rims redone... some twice...
I'm ready for something new, want to go to 18's.... read a bunch of stuff on the 18's here on the forum, seems like a good fit for me, its a daily driver for the wife.
May even drop it an inch, don't think she will notice
i'm coming across 18x8 114mm bolt circle with 35mm offset and ive seen 45mm offset....
Which is correct ?
Which is correct ?
Start by reading this thread.
https://www.clublexus.com/forums/sho...d.php?t=311637
Then this one
https://www.clublexus.com/forums/sho...=534933&page=1
And that should answer any and all wheel related questions you can come up with
Then this one
Thanks you so much for pointing me in the right direction without trashing me I did do some searches but apparently not good enough ones to find the chart LOL
At this point I wonder how much of a ride difference there is with 18's versus19's ?
Will read the 2 links top to bottom..
Thanks again
Thanks again
