Lost transponder for key
Old 09-01-12, 08:41 AM
DJJACKSON5
DJJACKSON5's Avatar
Default Lost transponder for key
I need help!!! I lost my transponder from my only master key. I have a 2001 GS300 what can I do? The Lexus dealer wants about 800 dollars. Can I buy a key from ebay and have a locksmith flash my computer to reset a new key?
Old 09-01-12, 10:57 AM
USMCLexus
USMCLexus's Avatar
Dude, you meant $80.00 okay? Not $800.00. Got it?
Old 09-01-12, 01:29 PM
hobojoe
hobojoe's Avatar
I just had this issue with a 98 gs300 I bought with only the valet key. MOST dealers not all will charge you for 2 new keys and labor and will replace the ECU for the alarm system since they say they can't reprogram the transponders if you don't have the originally programming.
The option I went with is buying a brand new master key with the transponder from the Sewell Lexus parts site online for 150. Then I asked them what they would do and he said they just re-flash the ecu but most of the charge is labor for pulling and then re-installing it. So I found a locksmith with the capability to do so, pulled my ecu and took it to him. He re-flashed it, cut the key I had bought, and programmed it to the ECU for 150. Had he had to pull the ECU himself he said it would have been 350.
That's the route I would go unless you want 2 new master keys then your getting closer to the range of what the dealer charges and the cost difference is less substantial.
Old 09-02-12, 02:06 AM
G's Up
G's Up's Avatar
Or deal with these guys that will probably have more down time
http://www.ebay.com/itm/Lexus-engine...#ht_711wt_1037
If you can find a key with a transponder synced to the ecu like the one I bought
https://www.clublexus.com/forums/2ge...-with-key.html
And after swapping mine; the one I sold
https://www.clublexus.com/forums/2ge...0-ecu-key.html
Old 09-03-12, 08:18 AM
DJJACKSON5
DJJACKSON5's Avatar
I am all woman. LOL The dealer wanted $800 dollars for all, that would be two keys and to change the ECU for the new keys.
Old 09-03-12, 08:19 AM
DJJACKSON5
DJJACKSON5's Avatar
Thank you that is what I am going to do.
Kadrian87
09-22-16 04:24 PM
missblondi
RX - 1st Gen (1999-2003)
10-01-10 09:17 AM
SloStng
06-10-10 08:53 PM
Lexus 4 ME
GX - 1st Gen (2003-2009)
13
04-06-09 10:20 PM
BigRich
08-05-04 07:30 PM
Quick Reply: Lost transponder for key
