Help vsc, abs light on
Old 09-01-12, 08:39 PM
SynicalVip
SynicalVip's Avatar
Default Help vsc, abs light on
Got a 98 gs300, ive search and did all the things that everyone posted and yet it is still on! The abs, vsc lights stay on, I have tried doing the reset and yet nothing. Braking on the car don't feel normal anymore, u have to press pretty deep so it will brake. I have bleed the brake several times and it would get pressure/hard when I bleed but after close all valve and test drive to back to the same. So my thought is the master cylinder out? There always squeaking noise when you press and release the brake as well. With all these lights on it seem to be draining the battery and the car can barely start right up. Another thing I think it may be is the abs sensor/line broken?? Have replace the lower ball joint awhile back
Old 09-01-12, 08:56 PM
clos430
clos430's Avatar
First thing I would do is check for the codes causing the lights to come on!
Old 09-01-12, 11:17 PM
lextout
lextout's Avatar
Your brake master cylinder could be bad, i had bad brake pressure when mine failed, brake pedal to the floor symptoms.
Old 09-02-12, 04:54 AM
SynicalVip
SynicalVip's Avatar
The brake pedal not to the floor yet it still brakes but it's pretty far end than normal on braking
Old 09-06-12, 10:28 PM
SynicalVip
SynicalVip's Avatar
Forgot to add this, the lights came on after a brake job. Since I tried resetting it and it does not work, does that mean I will have to take it to the dealer to reset it?
Old 09-06-12, 11:07 PM
Emendoza
Emendoza's Avatar
any help with this issue yet? My gs has the same problem (abs and vsc lights on) but braking is fine, new brakes and rotors all around. I was told maybe speed sensor?
Old 09-06-12, 11:10 PM
SynicalVip
SynicalVip's Avatar
Same thing I was told, but then kept searching and reading some say the lights come on if you do a brake/pad job and not remove the sensor before doing it in which I didn't before hand so now those lights are on
ThatGuyJ
08-27-19 05:06 PM
chungmeow
09-25-15 11:48 PM
dl11
Performance
22
03-10-14 08:54 PM
781rolo
12-14-13 01:16 PM
ReMARKable
Suspension and Brakes
03-09-13 10:17 AM
Quick Reply: Help vsc, abs light on
