2000 GS300 Idle Problem
I had my A/C Compressor replaced and afterwards I have started to have idle issues when I cut the A/C on and when it gets hot outside sometimes. Is there something that I can adjust or being that my model is mainly ran off computers will I need to take it to a dealer and have them adjust something?
Thanks in advance for any help.
Correct, I am hoping someone on the forum has a solution. I am hoping this is not damaging the motor because I am ready to begin my build and this is the last thing I need.
Try cleaning the throttle body by wipeing it out with a rag wet with throttle body or carb cleaner. Hold the blades open while doing this. Disconnect the battery for a bit also, I have had luck doing this with alot of the early fly by wire cars/trucks
I have the same problem, though just barely noticeable. Turn on the A/C and the RPM's fluctuate a bit but quickly quits. Replaced battery, cleaned throttle body, and IACV, replaced TPS, tightened throttle bolt, replaced spark plugs and wires, and so on and it still is the same. PS-I did not replace those parts cause of the A/C idle stuff! I'm not that weird:/
guod
Performance & Maintenance
07-17-09 12:48 PM
