Help, Gs300 with GTE power steering problem
I have 99 Gs300 with Aristo VVT-I Swap , for some reason my powersteering pump not working and keep leaking fluid out everytime i fill it up,
My question is Can i replace powersteering unit with the one from regular IS300 or GS300 ?
What type of fluid did you use? If you used actual power steering fluid it can leak out of the seal, these pumps must be used with DEXTRON ATF fluid.
Otherwise you can use a pump from a 1JZ, a Supra GTE, and yes the GS/IS GE pumps will also work once you remove the reservoir cup off of it then you can bolt on the nipple from the GTE pump.
larryhirs
04-29-24 05:41 PM
Daspyda
09-24-15 01:56 PM
