VSC button not working?
As the title says, my VSC button doesn't work. No matter how long I hold it down, nothing happens. Is there a fuse for this or relay or something I can inspect? I've searched and nothing that helps with the situation.
iModerate
I think its this one. Found this pic in an unrelated thread and circled it for you. I will look when I go home in a couple of hours and let you know if this is incorrect but I 99% sure this is correct.
If that does not come on when you start the car the bulb may be out.
iModerate
Salvage car? Sometimes the bulb will be removed to mask the fact that the vehicle has issues. You can have the ABS/VSC system scanned to see what Diagnostic Trouble Codes are present. They may indicate what is causing whatever issue you are experiencing.
In addition, the car runs perfectly, ive heard that they run in limp mode if those lights come on. Unless, if the fuse was to be put back in(if removed) then it'll run like crap, then that would be the case. Any ideas where to check?
saulgs430
01-12-15 02:12 AM
