Will '03+ caster arm fit '99 GS3
Not too bad, but I was tired afterwards. I used a 2 ton jack (jack stand was there there as a backup). You would need a 18-24" breaker bar. Hardest part is getting the new one in. You nee a big crescent wrench so you can turn the arm a little bit while installing the second end. If you search the topic, you'll know what I talking about.
