key fob locking issue
Old 09-19-12, 12:11 PM
Shoegum
Shoegum's Avatar
Default key fob locking issue
I searched and did not find a post similar...so here we go. Unlock button works fine but the car will not lock with the key fob. Indication light lights up but the car does nothing. Panic feature with the lock button works fine. Car gave me a long beep at some point but not sure what I did to make it beep at me. Any advice on getting it to lock with the key fob?
Old 09-19-12, 12:18 PM
abounly
abounly's Avatar
Long beep means a door isn't closed.
Old 09-19-12, 12:28 PM
Debonair
iModerate
Debonair's Avatar
Change the battery in the key. Sounds odd but trust me.
Do all the doors not lock or just one?
Old 09-19-12, 12:33 PM
Shoegum
Shoegum's Avatar
ok update. even the unlock and lock on the door now is not responding. When i hit the lock key on the fob and put my ear up to the door I hear something trying to happen in there but nothing does. Also when I lock the car manually I cannot unlock the vehicle wiht the fob but it beeps like it did something...
Old 09-20-12, 06:19 AM
Shoegum
Shoegum's Avatar
no ideas? Another update. After the car sat the night the unlock opened. Could it be weak electrical? Im still baffled. Would a aftermarket security system fix the issue?
Old 09-20-12, 07:51 AM
Debonair
iModerate
Debonair's Avatar
Did you change the battery in the key yet?
Old 09-20-12, 08:12 AM
Shoegum
Shoegum's Avatar
I did not because the fob seems to be working properly. Also I am scared to take the battery out and not be able to reprogram the fob.
To me the fob battery cant be the issue since when I get in the car the lock/unlock button on the door also will not unlock/lock the car.
Old 09-20-12, 01:31 PM
Shoegum
Shoegum's Avatar
Could this be faulty lock actuators all around? I see post to replace these but no symptoms...
Old 09-20-12, 03:20 PM
acky87
10th Gear
acky87's Avatar
You dont have to reprogram the fob after you put a new battery in
Moonyvuong
05-06-19 05:12 PM
shoebopper
04-01-13 10:09 AM
BC8
12-09-12 12:22 PM
98023IS250
10-31-09 09:45 AM
dennis1a
ES - 5th Gen (2007-2012)
11-11-06 09:45 AM
Quick Reply: key fob locking issue
