Help!! New 01+ master cylinder installed on 99 gs4 - still have vsc/abs lights! Help!
Old 09-20-12, 10:12 AM
wutiteez
wutiteez's Avatar
Default Help!! New 01+ master cylinder installed on 99 gs4 - still have vsc/abs lights! Help!
I recently purchased a 2003 gs300 master cylinder and had it professionally installed on my 99 gs400. Brakes work fine now and no more "baby screaming" buzzing noise but the VSC/ABS/VSC OFF lights are still on.
Searched all over the place for this issue but I cant seem to find the solution or anyone who has fixed this same issue. Its already been 3 weeks and my car is still sitting at the shop after triple checking everything.
Ran the codes and it came out with:
c1246 - master cylinder pressure sensor fault
c1223 - abs system fault
Supposedly, the reason why c1223 is on is because c1246 is on. And I know you have to do some modifications on the pressure sensor since the 01+ BMC are different. The shop wired it correctly but lights are still on.
Lexus wants $400+ for a new master cylinder pressure sensor but which one should I get? the one for 98-00 or 01+? anything else I should check before forking out another $400+?? HELP!!!
Old 09-20-12, 12:27 PM
porn-adkt
porn-adkt's Avatar
Sounds like the shop messed up.
1. No wiring is required. Only swap sensors. Your computer will not recognize 01 sensor if your car is not 01.
2. They should have reset the codes..
Old 09-20-12, 12:36 PM
wutiteez
wutiteez's Avatar
so they should have taken out my old pressure sensor from the 99 master cylinder and put it on the new master cylinder? Im gonna tell them and will keep you guys updated!!
Old 09-20-12, 12:41 PM
porn-adkt
porn-adkt's Avatar
YES.. This info can be gathered from doing a simple search and taking time to educate yourself even if your not mechanically inclined. Its there to help you from CONDITIONS as yours..
The 01 sensor will not plug into the 99 harness in addition to not reading correctly, so unless they had the pigtail...Im curious to see the monstrosity..
Old 09-20-12, 01:05 PM
wutiteez
wutiteez's Avatar
I searched everywhere but all I found on here and through google were to get a new pressure sensor. and I couldnt find anything on specifically removing the old sensor and put it onto the new one. I guess they didnt do that and instead somehow wired it to fit the new sensor.
Old 09-20-12, 05:12 PM
sakataj
sakataj's Avatar
then you didnt actually search on here, almost EVERY thread on these mentions removing the old sensor and reusing it.
Old 09-21-12, 07:43 AM
repugnante
repugnante's Avatar
LOL, yea man. That's the first order of business is to swap out those sensors
Old 09-21-12, 01:19 PM
wutiteez
wutiteez's Avatar
i wouldnt go out of my way to post this thread if I was able to find it. if you arent here to help out then please dont waste your own time and my time with your smart remarks
Old 09-22-12, 11:21 AM
sakataj
sakataj's Avatar
yeah noone, does that.....
and when you help yourself, like by actually searching and finding your own info you wont get responses you dont like. BTW i wasnt being smart, i was being serious.... you DIDNT search on here cause all the posts i looked up showed that you need to remove and reuse the sensor
Old 09-24-12, 01:34 PM
wutiteez
wutiteez's Avatar
when you're a lowlife who has 24/7 to be on this site and have nothing better in life to do, you'll find everything. So why dont you put that to use and do all of us a favor and post the links that you've found? Maybe someone else whose reading this thread may find it useful. I searched for "abs vsc light" "master cylinder" "master cylinder buzzing noise" ... and many more. Came across a lot of threads mentioning 01+ bmc are better for replacements but many stated to buy a new sensor and even some saying some wiring needs to be done, but none that I've seen specifying to swap the old sensor. My car has been sitting in the shop for a month and you think all this time I've been sitting on my a** not searching for a solution?
I also saw another thread, same situation, where you made snarky remarks to someone needing help as well and thanks to you, his thread got closed. So if you have ignorant opinions, keep it to yourself and instead help the members who need it and post what they cant find since you're such a genius at finding everything
Old 09-24-12, 02:00 PM
sakataj
sakataj's Avatar
lol, im in medical leave from my 2 jobs...so yeah i am on here lately even more than before
your asking me to post you a link now? you just called me a lowlife remember,why would i post you anything? im not a genius at finding things, i just actually look for them not just saying i searched and ask people to post things for me. i hope you get your info and your car fixed,this lowlife's car is working fine.
Old 09-24-12, 02:04 PM
99 GS3
99 GS3's Avatar
You may also need to do the TC + E1 reset on the DLC under the hood to reset/clear the codes.
Old 09-24-12, 02:55 PM
wutiteez
wutiteez's Avatar
Yeah we tried that but the codes still stayed on. But they finally fixed it with the sensors!
aznguywu
Suspension and Brakes
08-04-17 11:09 AM
gs400owner
03-30-15 10:18 AM
dl11
Performance
22
03-10-14 08:54 PM
Dan_K
12-11-06 02:53 AM
jettie1767
10-21-06 12:55 PM
Quick Reply: Help!! New 01+ master cylinder installed on 99 gs4 - still have vsc/abs lights! Help!
