Moon roof sun roof rattle
OP check the surrounds of the sunroof and make sure none of the arms are broken and that the tracks are clear.this caused a rattle in my car till i got it fixed and caused me sometimes to have to push the button more than once to close it
also OP just to let you know, the + sign right after the quote button will allow you to respond to alot of people in one post all at once.
Decided to step outside and take a look. There's a plastic piece on the outside of the metal track that rattles when the sunroof is open, but doesn't after pressing the open button once more.
Also as Brian noted, please use this button in the future to reduce the clutter.
My wind bar rattles occasionally at high speeds, which is what I thought you were experiencing. My sunroof only made noise in the same place that yours does after using a little bit of force. I was able to pinpoint it down to the plastic strip on the outside of the metal track. It did not make this noise once I pushed the open button a second time.
You can fix your wind bar rattle with a little felt like I said. Make sure the felt is thin or the wind bar will be too low and you will get wind flutter.
I just drove on an errand an my rattle is not the plastic piece, it sounda like its behind me. It only does it occasionally on certain types of bumpy roads.
lexusscturbo
CL of Southern California
12-19-09 03:26 PM
