Seat Belt Warning Light??
If you weigh less than 150 lbs and sit in the passenger seat of my GS3 without fastening your seat belt, the seat Belt warning light won't come on unless you push your butt way back in the seat. If you weigh 150 lbs+, it will flash like it is supposed to. My son and daughter are around 110 and 125 lbs and they have to sit way back and perfectly straight in the seat before the light will flash to remind them to put on their seat belt.
Are their any adjustments I can make to fix this. Lexus Dealer told me the pressure sensor is set at 35 lbs.
I had it checked out Friday. THey are gonna repair under warranty. 3-4 hrs because they have to take to upholstry shop to get seat cover removed. I've finally found a good service ops mgr.
That's an idea. Now, if I can only find the right plug under the seat. I want it eitehr to work or not work. None of this 1/2 way on, 1/2 off stuff. I'll check it out .
tjhood
03-25-09 08:05 AM
