DIY for brake pads???
hey guys is there any DIY on replacing brake pads on 98 gs400? used the search bar but no luck.
please help me out! dealer wants $240 per axel and i thing thats ridiculous. a link with pictures would be really appreciated
It's easy. lift your car and secure it with jack stands. Take off your wheel and turn it away from you to make it easier to work. Just remove 2 bolts that hold the top of the caliper on and pull it off. Replace the brake pads. Remove you oil cap and compress your pistons. Then put everything back together. I'll try to do a full DIY with pics later.
Check this out: http://www.lexls.com/tutorials/brake/ goober.
It is an LS tutorial but very similar to GS, I will post the DIY from my manual when I get the chance.
Also, I found that first link using the Hello all thread. It is a good one: https://www.clublexus.com/forums/gs-...ou-search.html
I uploaded this pdf from my Service Manual. You should look for the service manual online, it is a great tool. http://pdfcast.org/pdf/1998-2005-lex...-brake-pad-diy
Thanks for the suggestion fellas! i'll attempt to replace both front and rear pads! if things went well ill post few pictures hoping to help someone in the future
rrr
08-04-09 09:17 AM
