Gs300 Idle Problem.
Hello CL! Have a problem with my 2001 GS300, i had a bad vibration problem a couple of months ago, i went and changed motor mounts, spark plugs, air filter, timing belt, it help alot, but when i start the car in the morning it idles in the 900's but when i leave and stop at the first light the idle goes down to 400 and its vibrates alot! But suddenly it goes back to maybe 700, but it still vibrates. Please help! I hate this vibration! I havent changed the fuel filter, would it help? It has 142,000 miles on it.
Thanks
Mike
Thanks
Mike
GS300 IACV http://www.partsgeek.com/gbproducts/...FShxQgodzU8ATA
To clean the MAF just use CRC or something similar. There is probably a DIY somewere on this site.
OP, did you ever find out your problem? I understand this thread is 2 years old, if someone else knows a fix to this, I have the same exact problem and recently had those repairs done as well.
Airbox as in your air intake where the filter is? I used to have a stock air intake that was cracked as well, never got a CEL. I changed to a Weapon R Dragon Air Intake System and have been good. I did some more research, it could be my OCV or TPS sensor. I did have a limp mode problem 2 years ago, got it fixed. Maybe it is underlying problem with a used TPS sensor or something. First going to check OCV, clean filter, and that doesn't help, I will go to the next.
danielaj
06-05-13 08:30 PM
97-SC300
01-27-11 09:18 AM
