Post up your gauge setup for those with FI setup
I tried to do a bit of searching but didn't see too much come up.
So I want to ask/see, for those who are swapped what is your gauge setup?
Which gauges did you get, and what brand?
I've been thinking of Prosport, STRI, Defi, AEM?
Not sure if it helps, but I'm doing the GTE route.
FWIW, this is the list of gauges I was going to run when I went NA-T:
-Boost (obvious)
-Oil pressure
-Fuel pressure
-Wideband O2
-Trans temp
The factory gauge for water temp would be enough, and Oil temp shouldn't be an issue on low boost stuff. I would choose the above list for aftermarket gauges as they're more detailed and accurate usually and that's the stuff you need to keep an eye on to prevent it from blowing up.
I'd probably do Oil pressure, Fuel pressure and Boost in a triple pillar pod, and either a double ash tray pod for trans temp and wideband or wideband on the column and trans temp in the ash tray.
My subie buddies all run ProSport stuff and love it. AEM makes a damn good wideband, so does Innovate. Defi are cool and work well, but pretty pricey.
-Boost (obvious)
-Oil pressure
-Fuel pressure
-Wideband O2
-Trans temp
nemean
SC- 1st Gen (1992-2000)
61
01-25-13 02:33 PM
