99 gs400 e-brake sticking
hey guys as the title says
e-brake is sticking even after i pull the handle to release it, i was able to free them when i put the car into reverse but now its getting worse, has this happen to you guys before? i hope the cables are not seizing
thanks for any input or tips guys
hey guys lubed up the cable a bit and worked good for a month or so. the outside of the cable was cracked, i guess water gets in and corrosion bla bla bla. i dont wanna lube this thing up every month. has anyone every replaced the parking brake cable? is it one piece from pedal to the rear brakes or sectioned off ?
I think its one piece of cable that runs from the pedal to the calipers. If its cracked it might just be easier to put some grease where you see the most damage and seal it up with electrical tape. Some worked involved in it but may be cheaper.
toy4life86
09-20-10 09:26 PM
TimsR1
10-12-06 05:54 PM
