what if you took the original fog light GS plastic housing, and if you could drill/hole saw two 2 inch holes in it without cracking the lens insert the ebay fogs into that lens shell/housing and paint the lens black?
How are you guys wiring them? Buying a fog light wiring kit or tapping into factory wiring?
When I do mine I will just use the factory wiring to fire up the relys that I will use to power my HID's. I think that the factory wireing will not be able to fire up my lights on their own.
Why cut the fins. Can't you just trim the fog light housing?
I know from the picture it looks like you can just cut the fog light housing, but the physical dimensions of the housing plus the lights requires you to cut the fins. The factory light is a lot shorter than the ebay fogs.
If you wanted to go through the trouble of making the ebay fogs fit the factory size hole you might run into trouble with the plastic housing it self. I think if you start hacking up the ebay fog light housing the plasic will just crack.
I was just talking to someone about this... Anyone have any input on this idea????
