Instrument Cluster Wire diagram (HELP)
I recently took my instrument cluster out & in the process I think i might have pulled a wire from one of the wireing harness connections.
My instrument cluster will not light up anymore and the little gas light is on... (my gas tank if full)
Does anybody have the pin diagram so i know which wire if for the lights and gas sensor??
All my Fuses are good, I can not see any wires out of the connector... but I know one is probably torn inside the insulation because when i wiggles them the instrument cluster worked fine up until i moved it.
I have the same problem in a way my airbag and open door warning lights dont light up when i turn on the car irs driving me buts dont know what keep me posted maybe ill check my wires also
