wheel experts need your input!!!!!!!!
ok so im thinking outside the box with this annoying clicking noise i cant seem to get my hands on.
ive been slightly losing tire pressure on a wheel its a 19x11 alumnium wheel. Can a cracked wheel cause a clicking noise while driving? only audioable when going 5-10 mph and cant hear it after 30 mph.
check your wheel bearing yet?
what is your aftermarket wheel hub size? running wheel hub rings if your center bore isnt 60.1 on the wheel size. Wheel would wobble if its not the right bore and would have cused your wheel bearing to go out.
i am taking it clicks like the axle would click going at those speed.
the click is still there going at 30mph. you just dont hear due to all the other factors. road noise and your moving forward breaking the sound berrier.
I've been at this for a while now..and my rear suspension is brand spanking new. Everything you can think of I changed...even my damn drive shaft.
The only thing I can think of is that crack on wheel, and the surface where the rim and hub meets probably dirty...this is a mind boggling problem.
It was a good suggestion...already checked there all good...the only reason why I believe that it's a cracked wheel causing the click is becuase I switched wheels, and the noise followed....just never heard about a crack on the wheels able to cause clicking...
ok guys problem solved. A crack on the wheel can cause clicking, and hear at low speeds. 1 click per tire revolution. at least my rear suspension is brand spankin new..lol.
vespid82
Suspension and Brakes
16
06-29-10 02:57 PM
