SRT ecu questions
SRT ecu questions
Hey guys,
I am thinking about getting an SRT piggyback, to take full advantage of my intake and exhaust. If I one day want to remove this after its been in the car for a while, will it cause any problems due to it changing any thing on the ecu? or will I be able to remove it no problem?
[QUOTE=AM21GS400;7619378]Hey guys,
I am thinking about getting an SRT piggyback, to take full advantage of my intake and exhaust. If I one day want to remove this after its been in the car for a while, will it cause any problems due to it changing any thing on the ecu? or will I be able to remove it no problem?[/QUOTE
no problems, whatsoever. just reconnect the wires after you take it out...
Forum Administrator
Not sure I quite understand what you are trying to do... you want to use the SRT ECU with some other brand of intake already on your car?
Looks like from this thread that you have a K&N
https://www.clublexus.com/forums/per...y-k-and-n.html
If that's the case, why aren't use using something like an Apexi that will be more tuneable/flexible (and not built for another, larger volume intake)?
JAYGS4NYC
12-14-12 02:48 PM
