what a bad day
Old 11-29-12, 05:06 AM
msarahalex
msarahalex's Avatar
Default what a bad day
was driving on the high way doing 60 miles, next thing i smell some thing like rubber burning and then the car starts shaking. i pull over thinking its a flat, jack up the car, took out the wheel only to see that the tire is done.
Attached Thumbnails what a bad day-lex-brea-011.jpg   what a bad day-lex-brea-008.jpg   what a bad day-lex-brea-010.jpg   what a bad day-lex-brea-013.jpg   what a bad day-lex-brea-018.jpg
Old 11-29-12, 05:25 AM
Lecoultre
Lecoultre's Avatar
That is tough on you - but moreover a blow out like that could be very dangerous and someone could have very easily been injured if the car careered out of control...
What make and type of tires were you driving on?
Great to see that you are still around safe and sound and up for the post...
Old 11-29-12, 05:45 AM
msarahalex
msarahalex's Avatar
they are work wheel varianza 19x9.5 front and 19x10.5 rear
Old 11-29-12, 06:00 AM
FinLIFE
FinLIFE's Avatar
Did that wheel come off the front left? If so then you had it on backwards just fyi
Old 11-29-12, 08:20 AM
veron1987
veron1987's Avatar
Yep ..looks like it.
Old 11-29-12, 09:59 AM
timtim14
timtim14's Avatar
yea definitely mounted backwards but is that what caused it because it doesn't look like there was much of a stretch going on. this kind of scares me because that could of been bad. Im happy your safe man
Old 11-29-12, 11:01 AM
neegroy
neegroy's Avatar
good thing you werent driving that fast. but yeah make sure you find out the brand and sizing of the tire bro.
Old 11-29-12, 11:07 AM
SC400slide
In Recovery Mode
SC400slide's Avatar
It could have been ton's worse. Glad your safe. A flat tire isn't as bad as it get's, believe me! Gl.
Old 11-29-12, 11:14 AM
abounly
abounly's Avatar
Not enough air pressure? Causes tire to debead when going over tough roads and kept driving causing it to blow.
Old 11-29-12, 11:18 AM
1sWt2GS
1sWt2GS's Avatar
yikes, looks scary
Old 11-29-12, 11:31 AM
vwynn
vwynn's Avatar
how many miles were on the tires?
Old 11-29-12, 12:47 PM
BCHDAZ
BCHDAZ's Avatar
look's like it's been chopping it'self, maybe on the ball-joint... you can see rub mark's next too the tear where it look's like it's been touching something.
Old 11-29-12, 12:56 PM
GS4_Fiend
GS4_Fiend's Avatar
Another falken tire story...
Old 11-29-12, 02:38 PM
msarahalex
msarahalex's Avatar
i took a look at the tire and turns out it was mounted back ward. only drove like 5000 miles on them. i bought the rims and tires from a guy in houston texas, he had them on his nissan 350z. i guess the shop he went to must have put them wrong. i should have checked the tire direction before i instaled them, but anyway things happen.
Old 11-29-12, 04:11 PM
MikeFoxx
MikeFoxx's Avatar
^^^^ You should check the others - glad this is all that happened def coulda been crazy
Quick Reply: what a bad day
