Driver Side Door Trigger Wire? (NEG)
Problem: I recently had an alarm installed and the "AUTO" function does not shut off my lights after leaving the car and arming it. It stays on for good.
Search Results: So I found out from searching that, I need to send a NEG signal from the alarm to the driver's side door ECU telling it that I have left the car.
https://www.clublexus.com/forums/lex...starter-2.html
http://us.lexusownersclub.com/forums...nd-headlights/
Question: Now, problem is, I've tried the red/white wire to no avail. I am using a relay since the signal from the alarm is only 200mA. Which wire is the correct one that I am supposed to tap into? My search went to a dead end here. Can someone chime in? Thanks
raine
12-21-09 04:03 PM
tritron
05-03-07 04:46 PM
