HELP with headlight please!!!!
Old 12-05-12, 05:21 PM
DosyBoy
DosyBoy's Avatar
Default HELP with headlight please!!!!
So I took out my headlight BULB on my drivers side to let the condensation out, went to put the bulb back in and it won't work, I even thought maybe I touched it against something so I ordered new bulbs which just came in, put the new bulb in and nothing.. I checked the fuses under the hood I think it's 43 or 44 and their both good.. What's wrong? Are their any other fuses I should check? Help please......
Old 12-05-12, 05:31 PM
LebShowoff
LebShowoff's Avatar
Did you pull the wires on the plug or just twisted it off?
Old 12-05-12, 05:33 PM
DosyBoy
DosyBoy's Avatar
I twisted and kinda pulled......
Old 12-05-12, 05:42 PM
DosyBoy
DosyBoy's Avatar
Cleaned it with alcohol it's on!!!!!!
Old 12-05-12, 05:45 PM
Mr Jokster
Mr Jokster's Avatar
Assuming you have factory HID's, make sure that when you push the harness on the bulb and twist that you pushed all the way in. I have that problem with one of mine. I'll swap bulbs to change color every now and then and I have to install and reinstall a few times before it works again. I noticed that the contacts arent making good contact.
I didnt think about it till right now, but iirc, you can bend the contacts a little on the inside of the harness 'outward' as to get better contact. Might help.
idk, my 2¢
Old 12-05-12, 06:46 PM
DosyBoy
DosyBoy's Avatar
idk, my 2¢
Yep and it wasn't plugged in the whole way, ty
Old 12-05-12, 07:48 PM
veron1987
veron1987's Avatar
Must've let out a huge sigh of relief huh?
Old 12-05-12, 07:56 PM
YxUxMADDDD
YxUxMADDDD's Avatar
that's what you get for messing with it lol.... ^^ as stated above.. i bet you nearly crapped in your pants huh? sweaty palms and all that hahaha
Old 12-05-12, 08:29 PM
DosyBoy
DosyBoy's Avatar
Awwwwwww I've never seen such a beautiful sight in all my life!!! My palms were leaking! Lump in the throat and knees shaking!!!!
Old 12-05-12, 08:30 PM
DosyBoy
DosyBoy's Avatar
U have no idea!..........
Old 12-05-12, 08:58 PM
GS4_Fiend
GS4_Fiend's Avatar
was gonna say loose connection but you got it. you could have confirmed that with a simple voltage check. If theres power then obvious it's a connection problem.
Old 12-06-12, 12:47 AM
aneidiaz
aneidiaz's Avatar
Don't you just love tools?
Old 12-06-12, 10:59 AM
Blanco
Blanco's Avatar
So whatever became of your wheels? Did you ever get them painted? How'd they turn out? Never saw a thread with pics.
suprsedan
IS F (2008-2014)
02-09-19 07:36 AM
Jaybeck860
IS - 1st Gen (2001-2005)
01-27-14 11:08 PM
Mrd916
IS F (2008-2014)
01-19-13 08:12 AM
ltzSupra
08-12-11 09:38 PM
mkorsu
Lighting
04-16-05 11:58 AM
Quick Reply: HELP with headlight please!!!!
