Correct exhaust flange gaskets?
Old 12-06-12, 03:04 PM
gumbo48
gumbo48's Avatar
Default Correct exhaust flange gaskets?
Hi all, I just wanted to verify that I ordered the correct parts before taking the exhaust apart. I've got a leak on the passenger side flange, right after the catalytic converter. Do these look like the right ones? Thanks.
Sorry, forgot to mention it's for a 2003 GS430.
Old 12-07-12, 07:01 AM
sakataj
sakataj's Avatar
did you just install PPE headers by any chance?
btw im pretty sure those are the crush gaskets for the rear canisters.....where it mounts above the axles. when i installed my greddy i used those but i forgot which side of the exhuast got them
Old 12-07-12, 10:36 AM
1sWt2GS
1sWt2GS's Avatar
doesnt look right, it should have a hole on both sides. and be more oval.
Old 12-07-12, 10:37 AM
1sWt2GS
1sWt2GS's Avatar
something like this
Old 12-08-12, 07:00 AM
gumbo48
gumbo48's Avatar
I haven't installed headers, the exhaust is stock as far as I can tell. The part number for these gaskets is 90917-06078. According to the diagram, it's the exact same part number for the gaskets that are right before the mufflers.
Old 12-18-12, 03:52 AM
gumbo48
gumbo48's Avatar
Well it turns out that they were the correct gaskets after all. The old ones were trashed.
Once we got done installing the new gaskets, there was a gap between the flanges and we thought that it was going to continue leaking but it didn't. Is it normal for it to have such a large gap?
What are these two fat pipes called? Would removing those and installing straight pipes make the exhaust a little louder?
Old 12-18-12, 07:16 AM
flowrider
flowrider's Avatar
Received 1,906 Likes on 1,343 Posts
^^^^The "fat pipes" are called resonators. See definition here:
http://www.ehow.com/about_5765675_ex...esonator_.html
Yes, removing them and replacing with straight pipe will increase the noise, but it may also increase rasp and change the tone.
The gap is OK as long as there is no leak.
Lou
Old 12-18-12, 08:13 AM
SC400slide
In Recovery Mode
SC400slide's Avatar
That is what my exhaust flanges looked like...they sealed the exhaust well...
Old 12-18-12, 09:12 AM
sakataj
sakataj's Avatar
Originally Posted by gumbo48
i have this large of a gap also.....one OEM gasket, one aftermarket (flat) gasket later and i still have a leak here.... i have been pulling the exhaust apart from dragging it im trying to decide now if i am gonna cut off and grind down the flanges to make them smooth to fit, remake this section of the exhaust, rework the flanges, weld shut the gap (mine actually is more prominent on the top)
sigh its really annoying
Old 12-18-12, 09:19 AM
Debonair
iModerate
Debonair's Avatar
If you search "Remove Resonator" in the 2GS forum you will find a LOT of threads on peoples experiences with the sound. Even some before and after videos like this:
hyboost
IS F (2008-2014)
35
07-14-17 07:37 AM
xoarz
CL of Hawaii
06-26-17 12:52 AM
naterry
12-05-11 09:33 AM
Rollaboy
20
05-03-11 05:48 AM
TruPlaya26
Performance
15
03-05-08 09:21 PM
Quick Reply: Correct exhaust flange gaskets?
